clock problem bugging the crap out of me
You said you tried to set it? Is it reseting everytime you shut the bike off? Maybe you havent set it. If not.... hold a and b button togather untill the "1" blinks. A button moves the adjuster from hour to minutes. B sets the hour/minute. If it keeps reseting itself then on your right side under the air intake cover, pull the plugs (Blue and grey) apart. Spray them with electrical cleaner, let sit to drain out, the plug back in.
k i will try the plug thing. but i have tried to set it but it just wont stop flashing and only flashs 1:00. The flashing 1:00 will not change no matter how long i ride. i have been reading about it just nobody has had it stuck on 1:00. but guessing its not getting the constant 12v. do you know where the fuse for the clock is located?
i thought i had the same problem for the past 5 years. until today this post motivated me to try again. it worked.
hold both the buttons together. try it a few times and you should get the flashing hour or minutes.
the part that messed me up before i think was the fact that i didn't know how to actually "set it" once you choose the time. no button set it. and if i turned the key back to off it would reset again. apparently you just have to wait for it for a few seconds and it sets itself as long as you don't keep pressing the buttons.
