Putting the 97 900rr back on the road
Okay peeps.. my 1997 CBR900RR has been sitting in the garage for the last 2 1/2 years. Everything is stock on it except for the exhaust. I'm ready to put it back on the road. Trying to get ideas on how much work and the things I need to pay attention to before riding it again...and yes (cringe) it has been sitting with the ethanol fuel in the tank so I know at least a carb kit will need to be done. Any ideas or advice from anyone that has brought one back to life after sitting that long would be appreciated. Working on a budget price to figure whenever I get started. Thanks! Sidenote: Yep -- I know I'm horrible for letting it sit that long!!
I would rinse out the tank a couple times, and the petcock. Pull the carbs, give them a thorough cleaning. While the carbs are off spray a little WD or similar penetrating lubricant in the intakes. Check the air filter. Once it running, check for worn brake pads on the front, oil & filter change, coolant flush & replace, brake fluid replace. Maybe some new spark plugs. How old are the tires, Air pressure? Then when winter comes maybe freshen up the forks, lube pivot point on shock linkage/swingarm pivot point. Check wheel bearing when getting new tires. They should be smooth and quite when on a wheel balancing stand. Then come spring take it to the track for some track days at NCBike with Roger Lyle's Motorcycle Xcitement RoadRacing School and Track Days.
Sebastionbear1
The Hurricane Saloon
09-05-2013 02:22 AM
06CBRF4i
07-22-2006 02:12 PM
