front fork restoration
Old 08-03-2016, 01:52 PM
Pmcarpentry's Avatar
Default front fork restoration
can anyone tell.me how best to restore the dirt/corrosion on the lower end of my forks. currently very unsightly. is there a good technique to restore to original or should I just paint them?
cheers
Old 08-03-2016, 02:37 PM
74demon's Avatar
That's some pretty bad pitting.
Hit it with a wire wheel and paint them.
Old 08-03-2016, 02:40 PM
isn't it just! the previous owner didn't clean it for years and then left it stood up for 3 years! cheers for the advice.
Old 08-03-2016, 02:47 PM
74demon's Avatar
looks like your calipers and wheel could use a coat as well...
Old 08-03-2016, 02:56 PM
and wheels, but it's a long journey! first I need to swap the engine then rebuild callipers, then head race, then swing arm bearing ....... you get the picture LOL!
Old 08-05-2016, 12:41 PM
pcmaher's Avatar
Don't use a wire wheel made of any type of steel that will corrode. The wheel will leave microscopic steel particles embedded in the aluminum, and that can start corrosion. This is a proven phenomenon. FYI, any type of steel wire brushing on aluminum parts is strictly forbidden in the aerospace industry. Use a scotch-brite or brass bristle wheel, or aluminum oxide sand paper.
Old 08-05-2016, 01:44 PM
cheers for that advice. hadn't even considered that!
Old 08-10-2016, 10:53 PM
tomk1960's Avatar
I have restored many sets of fork legs by completely disassembling them, then degrease, then mask off all openings. I media blast with aluminum oxide, wash, dry, outgas, then powder coat with a finish that matches the original. They look nicer than new and the finish will outlast paint. The best time to do this is when you have to replace leaking fork seals. They're off the bike and already apart, so why not do it right?
Note that badly rusted or corroded parts will have pitting that may show through the new finish, but the parts will still look a LOT better.
Tom
Old 08-11-2016, 10:39 PM
Jaybird180's Avatar
Very nice
87hcane
08-30-2008 10:11 PM
gwynsgarth
12-19-2007 06:35 AM
gwynsgarth
12-18-2007 12:34 PM
photo2u
08-28-2007 11:16 AM
ozrider
09-02-2005 03:46 AM
Quick Reply: front fork restoration
