fitting scottoiler question
Old 11-09-2011, 12:44 PM
cbrjohn's Avatar
Default fitting scottoiler question
hi guys i have a 97 blade v model and bought a scottoiler for her. can someone please tell me if i can connect the vacuim pipe from scottoiler to the vacuim pipe coming from the petrol tap.or would this be a bad idea. if so wher else would i find a vacuim take of point. cheers guys for any replies
Old 11-09-2011, 07:20 PM
MadHattr059's Avatar
Ought to work fine, as long as you ensure no air leaks. Just get a 'T'-connector from a aquarium/pet store and some extra hose.
Ern
Old 11-11-2011, 11:08 AM
cbrjohn's Avatar
Default scottoiler
thanks for your reply but all is fitted now i found another vacuim feed as i didnt really like to cut into the vacuim pipe coming from the fuel tap incase it wasnt air tight when finished so i looked a bit harder and found one of the vacuim feeds thats used for connecting gadges for ballancing the carbs and connected to this all working now thanks guys
Old 11-11-2011, 05:53 PM
The sync ports are a good option as well. I recommended the fuel tank vacume line because it is already the farthest routed to the rear of the bike, where the oiler mounts.
Glad you got it worked out, Ern
Old 11-12-2011, 01:32 PM
cbrjohn's Avatar
cheers mate safe riding
CosmoBob
07-04-2011 07:18 AM
MadDogMcQ
How-To: Mechanical
05-09-2010 04:24 AM
hardassfunk
06-06-2008 06:09 PM
jpramondon
02-07-2008 10:19 AM
ali
03-14-2006 06:49 PM
Quick Reply: fitting scottoiler question
