Bike is freaking me out!
Random misfire that started in cyl #3 then jumped to #2 and now it's misfiring in cyl #1 each time it "jumps" the previous cylinder returns to normal as verified by spraying the head pipes with a mist of water.
I've taken the carbs completely apart and replaced every o-ring/seal possible and cleaned every orfice. Just last week the bike was running beautifully but now I'm losing it. I even tried doing the c.o.p. conversion and still had the misfire jump from cylinder to cylinder.
Anyone else ever had this problem? Could a bad pulser coil be the culprit??
Thanks in advence
Thanks in advence
What do the plugs look like? When you said it was jumping between 2&3, I figured coil since those two cylinders are on the same coil. But its odd that it jumped to #1.
Anymore back story on this bike? Did you recently acquire it or has it been a daily rider for you? Was it just this issue that developed that caused you to start messing with the carbs?
