95 CBR 900 RR Build
#212
the calipers are finished w/brembo logo and i got about 1/4 of the wiring done on the cluster enough to see that it works anyway. i am going to wait untill i get the front of the bike put back together to trim the mesh if it even needs it. My next hurdle after this will be to some how put a fuel sending unit in the tank so the fuel gauge will work.
#213
i got the cluster wired up and my new DBS Orange grips came in, so now im waiting on my new Clip ons,Throttle Assemble and tube,windscreen and my LED heat/Volt readout and some fork parts from vinman911. No new pics everything still looks the same at the moment.
#214
Thanks to Vinman i got the parts i needed to finish the forks, and got the cluster wired up. i got my new clip ons and grips in havent installed them yet i have to measure to see how much i need to adjust the clip ons in. My windscreen also came so i need to figure out how much i need to trim on the mesh mount for the cluster. I still need to fab a bracket for the new speed sensor for the cluster and get the racing alum tire valves installed. im still waiting for my temp/volt readout and my throttle assembley and tube.
The ends will be cut off of these so i can mount the End cap LED turn signals
She still looks a mess right now but im hoping i can get all of this buttoned up and looking good within the next week.
#216
i got the forks completely done now, the cluster is wired and mounted,new windscreen installed and i got the clip ons on the bike with most of the controls mounted. i did have to put some vinyl wrap on the windscreen to hide the mesh mounting points i tried to get it to match the paint scheme. the new throttle assembly is supposed to be delivered today so hopefully i can get everything mounted on the clip ons then put the grips on and mount the lighted bar ends. i cant say that i really care for the new clip ons but they are better than the stock ones. the wheels were sent out to a shop to have the new valves installed and rebalanced when i get those back ill bleed the brakes and it should be ridable.
the new clip ons are not a perfect fit with the controls i had to bend the bracket for the brake master cyclinder to make it stand upright again.
ill try to go out today and get some black wire loom to clean up all the wiring and make it look neat. thats all for now i guess hopefully the next post will be it finished!!
#218
i was feeling good because i got all the wiring cleaned up and looking and then it went south from there fast, #1 the new alum throttle assembly i ordered will not fit the bike the throttle cables wont screw into it, then after cleaning up all the wires i did a final check on the cluster it tested out fine until i fired up the bike and then no tach display. After about an hour of reconnecting wires and tearing up all the nice work i had just did ive come to the conclusion thats its the cluster itself so now i get to send emails trying to get a working one and a propley fit throttle assembly .......joy. But for at least a few minutes it looked good.
#219
i got the heat/volt/time display installed today almost killed my self in the heat. but here is some pics i havent put the surround on it yet i still have to make it (so it looks nice) here is some pics:
Volt mode
Time
Temp
These are the mode buttons that i mounted on the forward part of the moudling peice.
Volt mode
Time
Temp
#220
