94 CBR900RR Fuse Locations
Old 06-30-2008, 11:37 AM
archie's Avatar
Default 94 CBR900RR Fuse Locations
A little background, got jumped by a van and as soon as the cables touch with van off, everything shorted. Now i am trying to find all the fuse locations. I know next to the right handle bar and a couple under the seat, any others i am missing? I hope that some fuse somewhere blew instead of sumthing else.....
Tried to search everywhere online and couldnt find anything on fuse locations, cant get my hands on a manual.
Old 06-30-2008, 11:38 AM
archie's Avatar
Default RE: 94 CBR900RR Fuse Locations
subscribed
Old 06-30-2008, 12:43 PM
If you have no power on anything, it is probably the main fuse. It is a 30 amp, and it is located on the starter relay switch, not in the fusebox by the right handlebar. The switch is mounted under the right side cover. Just a heads up, jumping a motorcycle from another vehicle is really likely to warp the lead plates in the battery (which are much thinner and more delicate than the plates in a car battery) and cause dead cells because they are not designed to handle the load and high temperature of a fast charge. $30 for a trickle charger is one of the better motorcycle investments I have made, and can actually charge the battery enough to start in a couple hours. The hardest part is fighting the temptation of getting on the road right away, especially if your bike is your main transport . . .
Old 06-30-2008, 12:48 PM
Clymer manual says the only fuses are the 30 amp in the starter relay, and the 5 fuses in the fusebox. Forgot to actually answer your question.
Old 06-30-2008, 03:38 PM
archie's Avatar
as soon as i get home, i HOPE this is the issue, any particular way in removing this side panel? Or is it really really simple
Old 06-30-2008, 05:47 PM
stynkmonkey's Avatar
It's really simple and you might even be able to access it just by taking off the seat. It's just on the side of the battery by the (+) terminal.
If you have to take the side cover off there are two screws by the tail light (one on top, under the back seat and one underneath the light) then the 2 allen head screws on the side and the two clips that hold both sides together.
Old 06-30-2008, 07:18 PM
archie's Avatar
well guys, tried to get away with the easy rode and just switch out the fuse. still no power though. Also heard that fuse's can be broke and look normal so i switched the main fuse. Still nothin, i do have a spare battery though.... Im milking the easy possibilities here before i have to accept that its something major. Thanks again guys, anyone near Phila?
Old 01-30-2017, 06:45 PM
Robin Tennant's Avatar
Default 94cbr600
[QUOTE=MI900RR;595011]Clymer manual says the only fuses are the 30 amp in the starter relay, and the 5 fuses in the fusebox. Forgot to actually answer where is the fuse box located
Old 02-06-2017, 10:20 PM
Vinman911's Avatar
Member & ROTM AUG 2013
Old 01-04-2020, 06:17 AM
Dahab DA's Avatar
Default Same problem
I got the same problem and i changed the fuse 30 apm 4 times and it still get burn and now i tried to change new starter it still no power or anything on or any light on the dashboard and I tried to put the old starter still the same problem...would like to get some good answer and help and I will pay for tht if anyone knows I will really appreciate tht
comodidit
05-29-2011 11:48 AM
ironcitykid
08-31-2006 02:54 AM
ox.
05-26-2006 12:13 AM
Tre CBRF4I
05-04-2006 06:05 PM
kamkind803
03-27-2006 04:48 PM
Quick Reply: 94 CBR900RR Fuse Locations
