THE BEST OIL
Old 01-25-2009, 06:39 PM
jutsin's Avatar
Default RE: THE BEST OIL
I just use standard Castrol 4t, 10w40... No problems
Old 01-25-2009, 09:37 PM
13brsxsrr's Avatar
What up people, I'm back from my hyatus. I've been running Repsol for about eight years and I love it. A friend of mine has a Eddy Current dyno and going from Motul to Repsol10w-50 I gained 1.2 hp (WHOOOOOAAAAAA!!!!!!!)on my 51.Not big by an means but hey I stick with what works.
Old 01-25-2009, 10:05 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Personally I always change the filter with an oil change. K&N filters are saaweet and Mobil 1 15/50 for me.
As long as you don't use Fram filters any oil change is good Oil to avoid is the energy conserving ...
Old 01-26-2009, 02:46 PM
jfunkRR's Avatar
Mobil1 FTW, Purolator Filters
Old 01-26-2009, 03:03 PM
bwayers's Avatar
ORIGINAL: polarissucks
Why is moly bad to have in oil. Honda sells a pro oil with moly in it. What does it do? And does honda manufacture the pro oil themselves ?
moly is fine to use if you have a dry clutch or your transmission is in a seperate casing from your motor
in all sport bikes though you have a wet clutch, meaning your engines oil also runs through your transmission
the moly will cause your clutch to slip and wear excessively
it can also be referred to as energy conserving or friction modified
Old 01-27-2009, 12:46 AM
Blue Fox's Avatar
Retired Moderator
I'm a Honda GN4 fan myself. Why not use the oil that Honda makes........therefore if it ever does break down from lack of lubrication......you could always say "it was your oil".
Honda GN4 costs the exact same as the others too.........and I always change the filter (OEM Honda filter) every oil change.
