2003 CBR600RR Starting Problem?!?! HELP
Old 09-05-2007, 06:46 AM
Default RE: 2003 CBR600RR Starting Problem?!?! HELP
I just assumed my battery has given a good amount of life over 4 years time and 12K miles, if I new one doesnt fix the problem then ill look further into it. Thanks for the info though. BTW, what is "HID ballasts"??
Old 09-06-2007, 11:34 AM
WoodyRR's Avatar
ORIGINAL: NextYearCubFan
It's the piece of equipment that the HID bulb connects to. If you go to your local grocery store and look up at the long-tube flourescent lights. they are sitting in ballasts. HID ballasts use more voltage than the OE bulbs.
Old 04-04-2008, 08:47 AM
I'm having the same issue. Once the bike temp reads about 220 I'll shut it off. When I try to restart it again itcranks slowly a few times and then stops cranking. If I let it cool down for 15 minutes it starts fine. I called the dealerand her suggested replacing the battery. $130 later and it still does the same (It probably needed to be replaced anyway. It was the original bat). How do you test the R/R to see if its bad?
Kti
09-14-2013 10:17 PM
cravenmohed2k
06-07-2011 01:13 PM
hellraiser
08-02-2008 03:20 PM
Quick Reply: 2003 CBR600RR Starting Problem?!?! HELP
