Oil?
Old 04-03-2008, 11:03 PM
Tillys600rr's Avatar
Default Oil?
ok me and a buddy are not seeing eye to eye here LOL......when u change your oil u shouild fill it where the oil goes to the top line in the view glass while the bike is standing up not whileon the kickstand correct?
Thanx Guys
Old 04-03-2008, 11:06 PM
skical's Avatar
Default RE: Oil?
Correct. Not on the Kickstand. And on a level surface.
ORIGINAL: Tillys600rr
ok me and a buddy are not seeing eye to eye here LOL......when u change your oil u shouild fill it where the oil goes to the top line in the view glass while the bike is standing up not while on the kickstand correct?
Thanx Guys
Old 04-03-2008, 11:56 PM
Default RE: Oil?
The best way to do it is on two stands, but if someone sits on it, that will do just fine. Also, it should be two thirds the way up between the lower and upper lines, not all the way to the top!
I have a question. I have been running the Spectro Semi for the last two oil changed but decided to go with the mobil1 full synth for this oil change. Its JASO cert and all that, I just wanted to know if anyone had any experience with it. Thanks in advance.
Old 04-04-2008, 02:29 AM
Default RE: Oil?
you are right..the best way to check oil capacity full is keeping the bike straight up right,not on the stand.if you do that you will overfill your bike with oil and it wont start or might give you black smoke after starting..
Old 04-04-2008, 02:32 AM
camaro_forums's Avatar
Default RE: Oil?
What if it's already up to the top? Will it harm the bike? When I got mine it had it filled all the way to the top
Old 04-04-2008, 08:08 AM
Default RE: Oil?
ORIGINAL: camaro_forums
Yea I knew that was right but he wasnt having it HAHA........just loosen the drain plug and eas it out dont take it out all the way just enough where the oil starts coming out till it gets down to the level thats right!!!
