What fuel filter and air filter should I use?
Old 12-15-2009, 09:05 PM
c_keeton600f4's Avatar
Default What fuel filter and air filter should I use?
Does it matter? What are the differences?
Opinions?
Old 12-17-2009, 01:40 AM
any help would be good
Old 12-17-2009, 12:30 PM
gotcbr's Avatar
I use stock Honda. Your question is kinda like - what shoes do you wear? ...you'll get a different answer from just about everyone. ;-)
I personally can't see paying the extra bucks for a K&N (or other) air filter, oil filter, etc, when for *general* use, the factory Honda filters are good.
Old 12-17-2009, 03:11 PM
MotoDan's Avatar
I have three letters that equate to three words.
O...E...M... Unless it's an exhaust system or some sort of engine performance part I buy Honda genuine parts. I even buy Honda oil petroleum/synthetic mix. That's the best way to go usually. It can be pricier than aftermarket stuff sometimes. But those parts will work best because that's what it was designed for.
And I think an OEM fuel filter is only 15 bucks or so. I am in need of one pretty bad. Mine's dry rotted nearly to hell.
Edit: I did forget to mention that my air filter is a K&N air filter. I bought that because its reusable. I've heard mixed rumors about K&N air filters. But mine seems to work fine.
Old 12-18-2009, 02:36 AM
thanks for the input. and i agree with the k&n filter. that's probably what i'll go with when mine needs to be replaced.
Old 12-27-2009, 04:41 AM
Innobbeks's Avatar
Sure. You could find a wrecked 919 and get what you need off of it..throttle bodies, fuel pump, tank, ecu..etc.
Old 12-28-2009, 08:26 AM
what?
Old 12-28-2009, 02:43 PM
mk2mike's Avatar
I Can't Sell Because I'm Hardheaded
Originally Posted by c_keeton600f4
what?
was thinking the same thing
Kopi Ko
10-01-2019 08:29 AM
lishfireman
08-16-2012 10:02 AM
Fool
F4i - Wanted
05-10-2010 02:05 PM
usndocjaysin
09-21-2007 10:18 AM
Quick Reply: What fuel filter and air filter should I use?
