Help splitting the crankcase! 1999 600 f4
#21
#22
Alright I'll do that, thanks. I'll get photobucket and post some pictures once everything is back together
#23
Where are the bolts for the mains located? And where do you think I could find replacements? Thanks
#24
My photos are here:
https://www.flickr.com/photos/morgan9283/
Here's second where 6th was slipping out:
https://www.flickr.com/photos/morgan...posted-public/
The wear on 6th where the fork contacted it:
I replace one other gear, I believe it was 3rd:
An acquaintance who does this job a lot was adamant that I repair the drum--the wear was just barely visible but measurable with a caliper. The drum isn't available and the replacements I ordered from ebay all had the same wear. He put a drop of weld on the spot and I filed it down with a dremel. I used a hardened dremel bit and then a coarse polishing compound until the fork passed through perfectly. I have photos of this if you'd like to me to post them.
Also be sure to check your bearings--the bearing on my shift drum was suspect.
I forgot to order orings, sealing washes and gaskets and as a result had a coolant leak once I put everything back together. How are the boots between your carbs and header? Mine were rock solid and were a pain to re-install, I should have ordered new ones.
Did you remove your cam chain tensioner? I did and moved the crank around to get the cam chain guide off the case. As a result I got the cam chain off by a toth on the cam sprockets and the bike didn't run so well initially.
Did you buy exhaust gaskets? They may not be necessary but you might as well buy them for re-assembly.
If you do pull the gears off the shaft be before careful to put them back on in the same orientation. The Chilton guide was a huge help as I got a few mixed up while they were apart. The manual says to replace the circlips so I did.
Oh and clean out your coarse filter while you're in there--mine had a ton of metal in it.
-morgan
#25
1999 Honda CBR600F4 A CRANKCASE | Ron Ayers
Should be eight #12 and two #10 bolts.
This would be your mains.
#26
#27
#28
https://m.flickr.com/#/photos/142601...7671715083566/
This is the link to my pictures
#29
#30
Okay, and no I'm working on putting it all back together right now. I saw that the shift dogs were grinded down so I just ordered a new transmission. I checked the forks and drum and they all looked great.
