Cheaper replacement parts?
Old 07-27-2016, 03:33 PM
Ivanivanovich's Avatar
Default Cheaper replacement parts?
Hello all,
I'm currently doing a full-blown cleaning/maintenance on my F4 thats' been sitting for about 1.5 years. I've been slowly pulling it apart, and it's come to my attention that I need to do a lot more replacement than I initially planned.
I had been using bike bandit as a source for OEM parts, but now that I'm getting down to the small stuff, it just seems way overpriced. ($23 a pop for float bowl gaskets, nearly $100 for anything metal that needs replaced.)
I mean. I understand the concepts of supply and demand would mean things are gonna be a little more expensive for a 16 year old bike, but is there anywhere that has the same stuff for a more reasonable price?
Or does anyone know of a different solution to replacing those float bowl gaskets with something non-OEM?
Thanks in advance! I can't wait to get this thing riding again.
Old 07-27-2016, 07:37 PM
coalminer frank's Avatar
Have you looked on ebay? I think I've seen carburetor gaskets on there, maybe made by K & L, I think.
Old 07-27-2016, 08:35 PM
Conrice's Avatar
I use a combo of bikebandit and ronayers for very specific parts. Sometimes, they're much cheaper on RonAyers than bikebandit, sometimes not...
Old 07-27-2016, 09:25 PM
i have used cheapcycleparts.com a lot in the past.
But basically you are going to spend some coin fixing things up correctly.
Old 07-31-2016, 08:49 AM
PossibleOne's Avatar
Welcome Crew Technician
Depending to you could always try sourcing used parts. Obviously there is some concern with doing so but if you absolutely must save some coin then you can get stuff at a fraction of the cost. Obviously not gaskets and such but you get the point. I mean short of searching individually a lot of OEM stuff is similar in costs in my experience. Bikebandit has the pricematch thing. I tend to search around a few sites and go with the average. Unfortunately these bikes kind of have a cap for what they can be worth in the end. They made quite a few and mostly seem to command similar prices.
Tsmalls06
05-08-2008 05:55 AM
97si
08-07-2007 01:59 PM
ddaren
01-20-2007 01:35 PM
jimmy2blazer
Riding Gear
05-19-2006 01:20 AM
OneWheelinRR
09-07-2005 03:02 PM
Quick Reply: Cheaper replacement parts?
