99/00 F4 Firing Order Questions?
Old 10-09-2007, 01:29 PM
jpw's Avatar
jpw
jpw is offline
Default 99/00 F4 Firing Order Questions?
If anyone knows the firing order on a 99F4 i'd appreciate the info. I've heard and read different combinations but unsure of the right one. I'm using this particular motor in a cart.
ok.....
1) Ok...lets say the order is (A) 1,2,4,3 or (B) 3,4,2,1. what i dont know is which direction they shouldgo. I guess there are only 2 options, but assuming you are starting with the plug closest to the throttle cable (on the far end) is it A or B?
2) What would be the issue if the plugs were crossed up? Would it not start, or would it start but miss etc?
3) Airbox on or off? Should the motor start fine with just the carbs on witout the airbox, of with the airbox off does it get too much air?
Dumb questions i know...but if i knew i would not be asking. Thanks@
Old 10-09-2007, 03:12 PM
Nauree's Avatar
Default RE: 99/00 F4 Firing Order Questions?
1.I'm fairly sure its 1234. #1 would be starting on the clutch lever side of the bike.
2.I've never tryed swaping the order and I'm sure it will damage the motor in some way.
3. It will start w/o the airbox on. Just don't work around a dirty area. Its their to clean the air in the first place.
Old 04-24-2020, 02:28 PM
fafster's Avatar
Default hopefully not too dumb answers
The White Dog website says it's 1-2-4-3 and I'm sure they're right
https://www.whitedogbikes.com/whited...r600-f4-specs/
Number 1 cylinder is the left hand one, number 4 cylinder is closest to the throttle cables.
I assume it would miss on at least two cylinders if the coils were crossed up.
Engine won't get too much air if the airbox is off but it might get too much dirt and particles in it.
Joe887766
09-16-2018 07:06 AM
lanceam24
F2 Tech
03-17-2011 11:26 PM
mac760
12-10-2008 09:39 PM
clegane
06-21-2008 10:56 PM
ttyger07
05-07-2008 11:20 PM
Quick Reply: 99/00 F4 Firing Order Questions?
