2000 CBR 600 F4 Wont Start
Old 01-26-2015, 01:09 PM
Bob Stuffle's Avatar
Default 2000 CBR 600 F4 Wont Start
I have a 2000 CBR 600 F4 that I have purchased from another person who on their last ride laid it over. Now I can't get it to start. I can get it to run for a few second on starting fluid, but that is it. When I turn it on by the key, I do not hear the pump priming, and there is no voltage going to the pump. Therefore, no fuel is getting to the carbs. I've tried jumpering the fuel pump directly to the battery, and there was no activity at the pump.
Old 01-29-2015, 03:51 AM
wheelnut's Avatar
Welcome Crew
hi bob and welcome to the forum , firstly get over to the new member section to say hello, to start with I would check all your fuses then wiring to make sure its ok, then check you have power to the pump
Old 02-12-2015, 02:25 AM
CJardine's Avatar
Track junkie & modaholic
Any updates on this Bob?
Old 02-12-2015, 11:53 AM
Default Nope
With the cold weather, I haven't had a chance to really check anything out yet with the un-insulated and non-heated garage...
Old 02-12-2015, 01:39 PM
CJardine's Avatar
Alright well, we are here for when the weather is nicer and your bike wil get up and running so you can ride it.
Old 02-12-2015, 03:00 PM
I believe that I am just going to have to brave the cold this weekend. The bike not running is really driving me nuts.
Old 02-12-2015, 03:07 PM
CJardine's Avatar
i totally get it, I used to wrench on my bike under an easy-up while it was raining with shoplights and a space heater. its crazy what we do just to get a little wrench time. in.
Old 04-15-2015, 08:56 PM
Default Wits End...
I have downloaded the Honda Service Manual and gone through the troubleshooting pages for fuel pump issues. I have replaced the fuel pump, the fuel cut-off relay and still have no fuel pump activity. I ran through the check again and according to the manual I now need to replace the fuel pump transfer relay. being that that relays function is to provide a contact closure, I have tried jumpering the contacts to the fuel cut off relay to bypass the fuel pump transfer relay and am getting the same results. Why won't this damn thing start?
Old 04-16-2015, 02:16 PM
My boss was checking over the schematics here at work and may have found where my problem is. The air vent solenoid valve relay feeds power downstream to everything else. I'll check it tonight and report back what I find.
Old 04-28-2015, 09:57 AM
I forgot to report. We went through the entire electrical system and came back to the fuel pump. The new fuel pump I had installed was bad out of the box. So that being said, it runs great, now...
Quick Reply: 2000 CBR 600 F4 Wont Start
