Is there a vacuum line from the carb to tank?
Old 06-06-2013, 07:05 PM
JLAvila's Avatar
Default Is there a vacuum line from the carb to tank?
Hey guys so my petcock is leaking and theres nothing I can do about it cause its riveted on and I have an extra petcock from a 97 cbr900 that needs a vacuum line unlike the f3. So question is, anyone have a solution for this?
Thanks
Justin
Old 06-06-2013, 11:02 PM
VALKYIE's Avatar
Get a used tank and petcock from ebay. Or plug the vac line on the 900 petcock and see if it works. Good luck
Old 06-07-2013, 05:03 AM
MadHattr059's Avatar
Plugging the 900 petcock won't work.
Running a hose off of the #2 carb manifold should though.
I say #2 because it should have a capped nipple already on it.
Ern
Old 06-07-2013, 01:19 PM
JLAvila's Avatar
Ern
Hey ern thanks. Where is it located? Its on the outside of the block yeah?
Old 06-07-2013, 01:36 PM
f3cbrAnt's Avatar
At about 7 o'clock on the intake throat
Shine a torch into the area you should be able to see number 2 quite easily
Old 06-07-2013, 07:11 PM
Carbs/cylinders are 1-4 left to right.
The ports are just below the carbs.
#1 usually has a screw cap in it.
#2 should have a nipple with a teeny-weeny hose clamp on a rubber cap.
Best do this when the bike is cool. It gets pretty toasty in that restricted space.
Ern
Old 06-08-2013, 02:34 AM
JLAvila's Avatar
Awesome guys thanks a ton, I got her running good!!
Deilke6
03-31-2013 09:38 AM
FuzzyWuzzyBear
F2 Tech
21
03-13-2013 06:51 PM
CBRnoobie
10-14-2010 06:16 PM
CBRnoobie
10-11-2010 01:20 PM
DECwakeboarder
03-28-2007 03:56 AM
Quick Reply: Is there a vacuum line from the carb to tank?
