Remove the throttle cable from the throttle grip?
Hey you guys,
I am trying to change the right side handlebar inner weight. I took the two screws off the switch housing. Now I can slide the throttle grip back and forth but can't get it off. If I can take the throttle cables off then I can slide the grip off. The manual said to just take them off and it will slide off, but does not explain on how to take the cables off the throttle grip. If anyone has ever done this or knows how to do this, any help will be appreciated.
Thanks
Thanks
Alright I have taken all the slack that I can from the handlebar side, so I might just have to go to the other side. Will it also work if I take off the handlebar and just slide it all out that way, so I can get to the holes where the clip is holding on?
PS. do you have any pics of how you can do this?
Hey you guys,
Thanks
Thanks
Yeah I didn't want to go through taking off the tank and air filter just to loosen the cable and have to put it back on. On the right side where the throttle tube is I just went ahead and took off the handlebar. I took the front brake master cylinder off, removed the stopper ring, slipped the handlebar up off the fork, and tuned the handlebar towards to windshield and the throttle tube slipped right off with the switch housing and all cables still connected. I was able to get the old inner weight out and put the new one in easier when I could move freely then just there by my motorcycle with the front wheel moving side to side.
Here is where I got the idea of doing it. Some screen shots of how I did it, but with leaving the throttle cables still on.
The following users liked this post:
Trowy88 (02-08-2021)
