Make your gas cap keyless (or if you lost your key) - CBR Forum - Enthusiast forums for Honda CBR Owners
Thread Tools Search this Thread
Old 01-20-2010, 05:12 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
Default Make your gas cap keyless (or if you lost your key)
I'm sure this has been done before, but here's a quickie 5min thing to do if your gas cap key goes missing like mine did.
There's a metal ring around the inside of the rubber gasket which you must remove first.
This gains access to 3 screws, which when removed, allows the locking mechanism to detach from the tank mount.
Once removed, remove the rubber seal between them, and the lock cylinder slides right out
Then remove the pins with pliers (they all come out one way), slide it back in, reassemble, and you are good to go!
(keep in mind, you will have to drill it first or pick it if its locked on your tank)
Old 01-22-2010, 10:45 PM
Retired Super Moderator
Very nice !! This is not at all what I thought it was going to be based on the description. I always wondered how it came apart. I guess it wouldn't be that difficult to re-key the lock to match your keys. Maybe getting a lock from ebay and taking parts to locksmith. Who knows...
Old 01-23-2010, 02:18 AM
Nice!! Job done. Screwdrivers make better keys at track days anyway!!
Old 03-30-2010, 08:14 AM
Quote:
My friend ended up using this gas cap for his honda track project bike actually...
since even a coke tab will open it now, it makes well for a track bike i'd imagine.
The local shop wanted too much money and I needed gas at the time, so this was an easy fix... you can do it while its still on your tank after you drill it also... I think I saw a guy on the forums here who did just that!
Thread Thread Starter Forum Replies Last Post
How to remove a locked gas cap AND make it "keyless" Taiden How-To: Mechanical 24 10-24-2011 10:26 PM
keyless gas cap secretdestroyers CBR 600F2 4 05-30-2011 04:54 PM
keyless gas cap who has one pointman CBR 600F3 8 07-19-2007 12:08 AM
Tags
954rr, cap, cbr, gas, honda, key, locking, lose, lost, make, missing, pick, remove, replace, seals
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
