Did I bleed the brakes improperly?
Old 09-05-2008, 05:59 PM
dragonxero13's Avatar
Default Did I bleed the brakes improperly?
So after finally getting my bleeder valve, I was able to install everything, align my wheels, bleed my brakes and so on. So I took it out on a ride and the wheel moves straight with no problems thanks to the string alignment, thanks to that fella that helped me with that link.
Now I'm checking the rear brakes. The rear brakes feel soft, so soft that I couldn't low side if I tried to. I would drive around my neighborhood at around 25 and stop ASAP as if something was coming out of no where. Using both front and rear brakes, the front brake is still strong, that I haven't touched yet. While my rear brakes feel really soft, because I Fed it up? I would press extremely hard on my rear brake and it would only feel about 15% of the front brake's stopping power. I used the old tube and wrench way and I'm thinking about buying a MityVac after this .. or just paying 80 for a mechanic to do it ..
Regardless, I just need some help or some kind of tips.
Old 09-05-2008, 06:28 PM
soccer13pro2007's Avatar
Default RE: Did I bleed the brakes improperly?
I dont know if you've already taken this into consideration, but the front brake is 70% of the bikes stopping power. Not to mention there is only one rotor on the rear and two on the front. I use my rear brake as a compliment to the front, it's not supposed to be as strong as the front, just helps out.
Old 09-05-2008, 06:35 PM
Yeah, I know. I still feel as if the rear brake is so soft... maybe too soft .. The lines are hard .. I didn't see any bubbles when I was about done bleeding it .. I've read all the tips that I should maybe have the brake pressed down for a night and see how that goes. ..Maybe I can get someone that rides to see if my rear brakes are too soft or if it's just me from not riding in so long.
Old 09-05-2008, 06:44 PM
it could be you bled them too much and now there's not enough fluid in the line to make a firm press
Not to say there's not fluid, just not sufficient amounts, the line could be full but you might need to fill the reservoir more
Old 09-05-2008, 06:59 PM
The reservoir is full. I topped it off and while I was tightening it it actually dripped out as well due to me tilting the reservoir to tighten it.
Old 09-05-2008, 08:43 PM
njdjh2o's Avatar
Sounds like you still have air in the lines, do the bleeding process again, the more you do it the firmer it will get.
Old 09-05-2008, 11:28 PM
Another thing to check is if the brake pedal is bottoming out on the exhaust. I've seen different manufacturers of exhaust systems route the pipes close to the pedal. When pressing the rear brake pedal, it hits at the bottom of the stroke and prevents full actuation. Not real common, but an easy visual to check.
christopher_CBR F4
04-25-2009 01:45 PM
aj_jensen73
How-To: Mechanical
01-23-2009 12:19 AM
some guy #2
03-08-2008 04:47 AM
Tortured Soul
06-28-2007 08:54 PM
krash
11-09-2006 12:22 AM
Quick Reply: Did I bleed the brakes improperly?
