Go Back   CBR Forum - Enthusiast forums for Honda CBR Owners > Past CBR Models > CBR 600F3
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 05-30-2008, 08:17 AM
Default Cam chain tensioner problems ...
What sort of miles have you guys been getting before you have some cam chain tensioner problems on your F3s?? ... I have less than 10,000 miles on my F3 and it never ever goes near the red line so I am hoping it won't be an issue for some time yet ...
Jules
This ad is not displayed to registered members.
Register your free account today and become a member on CBRForum!
Old 05-30-2008, 08:27 AM
Default RE: Cam chain tensioner problems ...
I just rolled 18k and have not had any issues...yet. I beat my bike prettyhard and that hasn't seemed to trigger anything. So far I have seen 2 '99 R6 bikes have the CCT go bad, one was raced and the other wasn't so I think it's just a matter of time for some applications.
__________________
-For rent
My CBRForum Buddy
: REDD
Old 05-30-2008, 08:44 AM
Do you think F3's are any better than the F2's were in the CCT department??
Jules
Old 05-30-2008, 09:06 AM
I think mine is bad also. It sounds like a small thunk while accelerating, is that correct? Is it bad to ride around like that or should I replace it this weekend?
__________________
97 CB-R1 600
(600 F3 with 01 R1 tail)
Old 05-30-2008, 09:12 AM
That sounds more like drive chain, you'll know when the CCT goes bad. At idle you'll hear a lowd metal to metal chain slapping noise because the cam chain is jumping around in the case with out tension, once you apply torque it goes away because it's then tensioned by the engine working
Oh, not sure Jules, I can't imagine that the F3 to F2 would be much diffrent. Have never actually looked for the CCT on my F3, but if it's placed anything like the R6 it's a simple fix if/when it does go.
__________________
-For rent
My CBRForum Buddy
: REDD
Old 05-30-2008, 09:58 AM
That's good to know,thanks. Now I have to find out what that thumping noise is.
__________________
97 CB-R1 600
Old 05-30-2008, 09:59 AM
Clean and oil your drive chain
__________________
-For rent
My CBRForum Buddy
: REDD
Old 05-30-2008, 10:08 AM
I had around 48K on mine before it needed to be replaced. Even if you do need to replace the CCT, it's a 10 minute job.
__________________
Courtney
Old 05-30-2008, 11:06 AM
I'm Gay All the Way and I Swallow
Bouncing off the revlimiter isn't what causes the poor CCT design to fail, it's the immediate backing-off of the throttle (letting it "snap" back) when in high RPM's that causes the failure. Even in instances where this isn't the case, CCT's have failed simply from poor design.
You know, I wish I could sit every Honda owner down in a room and tell them...
OEM CCT BUCK SALLS. DON'T REPLACE WITH OEM, GET A MANUAL CCT.
Hondas OEM CCT's have been failing since the early 60's. Do that math and you'll find Honda put those crap CCT's on every single bike since they came to America. There is absolutely no reason to replace a failed OEM tensioner with another OEM tensioner. It's retarded - there is no arguement about, "prefering OEM," or, "Honda put them on for a reason," or "the original lasted so long I might as well replace it with OEM."
Those are all ridiculous arguements and only insinuates that the rider doesn't intend on owning their bike for the duration of it's life - which may be the case. I've just never understood the, "half-***" frame of mind.
Here's the deal on CCT's:
They can say bye bye at any time. Mine went on my first F3 at around 13K miles.
The number one reason they begin failing is snapping off the throttle at high-RPM's (the hydraulic tensioner inside doesn't spring back into place fast enough).
Every problem with Honda's OEM tensioner can be solved with a manual CCT and a monkey can install it.
2 8mm bolts and ta-da.
Old 05-30-2008, 11:36 AM
That's some good info ^^. I usually never go OEM parts unless that's all I can get. I've never changed out a CCT so knowing how it works helps a lot. I looked into it more after this thread. Thanks man.
__________________
97 CB-R1 600
Tags
1996, 2002, 600, cam, cb, cbr, cbr600f4i, chain, f3, honda, noise, problems, tensioer, tension, tensioner
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for CBRforum.com content, comments, or advertising. CBRforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse CBRforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
