Brakes touching the disk
Old 03-02-2017, 05:23 AM
kriss310886's Avatar
Default Brakes touching the disk
I have a problem with the brakes touches the pads. And just on the left. What's going on? How can I get rid of this?
Old 03-02-2017, 06:38 AM
74demon's Avatar
A light rub is normal, but binding is not.
Old 03-02-2017, 06:41 AM
Never notice it before. But it sounds like its only on one side. How do I test if the disc are straight?
Old 03-03-2017, 12:18 PM
74demon's Avatar
Use a dial indicator and check for lateral runout.
Or..... spin the wheel and listen for even drag.
A warped rotor will shake during braking.
Old 03-05-2017, 03:52 PM
wes 17's Avatar
My brakes developed a "wooden" feel to them. (Sorry but that's the only way I can describe it).
I lifted the front end and heard a definite binding area on my right hand disc whilst spinning the wheel, not so much that as it came to a stop it rested at the bind but it was there nonetheless. By eye it was very difficult to see and I employed a dry wipe marker to finally identify the warp.
I now have a post in the wanted section for my troubles. Best of luck with yours mate.
Old 03-06-2017, 01:32 AM
Daniel Lunt's Avatar
insert a screwdriver and pry the pads away from the disc slightly then bleed the brake
Old 03-15-2017, 08:38 AM
Jaybird180's Avatar
There is a specification for how much runout is acceptable. I agree that unacceptable runout is visually perceptible in a simple spin test (just need a friend to lift the wheel, or put up on stands).
Also agree that bleeding brakes is the best maintenance that a bike can have.
600F4inoober
03-21-2017 04:23 PM
gump
03-08-2010 08:59 PM
ecd2004
09-29-2009 03:54 AM
TheX
11-10-2008 09:34 AM
c.love220
02-14-2007 03:54 AM
Quick Reply: Brakes touching the disk
