97 F3 factory fuel pump pressure?
Old 08-24-2016, 08:58 AM
CAJA's Avatar
Default 97 F3 factory fuel pump pressure?
How much pressure should produce factory fuel pump on F3?
After factory pump failure i try with two(on visual similar) pumps from another model(0,2 bar pressure) and sometimes bike work on 2,3 cylinder,gasoline smell on exaust...
Now i put it on gravity feed and bike working with no problems.
I inspect carburetors(float needle looks good),electric charge(13.7V),pump relay switch,buy new original fuel hoses,fuel filter,air filter,spark plugs...
What to do next?
Thanks!
Old 08-25-2016, 01:20 PM
The factory manual doesn't specify pressure. It specifies rate. It should produce a minimum of 700cc per minute. It doesn't state a max.
jamescbr87
F2 Tech
05-29-2012 10:57 AM
Procrastinator
11-15-2010 06:47 AM
zblad
12-05-2008 01:14 AM
Quick Reply: 97 F3 factory fuel pump pressure?
