Who has changed seals on leaky F2 forks?
Old 07-17-2008, 02:39 PM
notny41's Avatar
Default Who has changed seals on leaky F2 forks?
My questions are:
Is it hard to do?
Do you need any special tools?
Can a guy with a decent mechanical sense do this?
How long should it take?
What parts do I need to buy?
What should they cost?
...and finally...how do I do it?
Thanks!
Old 07-17-2008, 03:16 PM
Default RE: Who has changed seals on leaky F2 forks?
I have just done it on my F2.... and it was needed...
Since it was the first time, I did it, I took around 1 hour to take it apart, clean it and put it together with new seals.... so 2 hours for both forks...
If you have your Haynes or Clymer manual, it just to follow the manual.... But I had also the DVD from www.drivenandridden.com as a guide to maintance the forks... and there is a tip how to make your own tool to drive ind the seals....
There is no need for any special tool...
Old 07-17-2008, 09:37 PM
notny41's Avatar
So is it just the "dust seal" then or is there another seal inside the forks?
Old 07-20-2008, 08:01 PM
Acara1796's Avatar
I have change some many forks seals I have lost count. In fact the silverwing is on the rack waiting for me to change them. It isn't hard.
If the forks are leaking then it is the inner fork seal for sure. You will need to break them down to change them.
Old 07-20-2008, 08:20 PM
elmer's Avatar
The dust seals are the ones you can see, another term people use for them is wipers. If you pop them out theres the actual fork seal that is pressed down into the fork tube. search the forum some and you should find some threads where people ran into problems and I wrote a novel about how to do it and whatnot. But its not all that hard to do, you just need a wa to support the front end of the bike without the wheel and forks on it.
TyStrand
07-15-2011 08:54 PM
yog182
04-15-2011 07:03 AM
dyracuse
03-01-2011 08:55 PM
Ameer214
08-16-2006 07:21 AM
Quick Reply: Who has changed seals on leaky F2 forks?
