My 91 CBR600 F2 Project
#31
#32
I really should replace it with a relay. Then I'd have the best of both, switched and accurate.
#33
#34
You only need a relay if your going to hook it up on an ignition switched 12v wire. Then you use a relay and use the switch 12v to trigger the relay. The gauge is still hooked directly to the battery.
I was bored so I doodle a diagram.
#35
Here's my gauge. I used VHB tape and stuck it to the edge of the top triple by the right clipon. And yes it reads a bit low when hooked up the way I did it (no relay).
#37
Pretty cheap, I presume? Who was the seller?
My next race bike will not have a total-loss charging, like my last one, but it does have a turned-down rotor, so it does not charge as high as OEM, and I will need to charge it occasionally in between sessions at the track... this would make knowing when I must do so, really easy.
#38
<<<Pretty cheap, I presume? Who was the seller?>>>
This is the one I used. It's small and completely sealed. Only downside is it's a little hard to see in bright sunlight. Other than that it totally rocks.
#39
This is the one i bought
New 4 5 30V Digital Red Mini LED Auto Car Truck Voltage Volt Panel Meter | eBay
#40
Replaced the levers today with some Shorty ones in black. These are just the regular ebay ones, but the quality was surprisingly great on these.
Racing Short Brake Clutch Levers Honda 91 07 CBR 600 F2 F3 F4 F4i 93 99 CBR900RR | eBay
Got them for $27.80 shipped
Also replaced the clutch lever mounting bracket as mine was cracked.
These took a few minutes of riding to get used to but they feel much better and to me look a lot better also.
