92CBR600 F2-Intro
No. The number one vacuum line is either capped or hooked to a diaphragm type petcock. The two vent lines from the tank go to a evap cannister or to the atmosphere depending on being a 49 state or Calif model. Both the thin and thick hoses go from the nipples to the cannister on my Calif bike.
I had a problem with a sticking throttle. Checked all the usual suspects. It turned out that the stock handle bars are filled with rubber and there is a hole in the bar under the throttle and the rubber had squeezed out and would drag on the throttle tube. Take of the throttle and make sure nothing is binding there. Sometimes a handgrip will be pushed too far on the throttle and it will rub and drag.
Here is the skinny vacuum hose on the left side of the motor. This is connected to the skinny nipple on the gas tank.
Here is the right side of the airbox. This nipple is ghetto blocked. Should it stay blocked or do I connect it to something?
This is the carb on cylinder #2. Should this nipple be blocked off?
And finally, this is the carb on cylinder #3. The skinny vacuum hose is not connected to anything. Should it be? Should I just put a cap on it?
Just ordered an APE CCT, I will install it when I get back from vacation.
Took the bike around the block about 10 times. It bogs down if I job the throttle at low rpms, regains power if I ease into it. I will mess with the pilot screw a bit and try to get some power down low. If not, I will look into some jet kits.
Put the fairings back on. They are beatttttt up lol
I need to do an oil change, transmission fluid change, coolant, get my chain tight, headlight bulb, rear signals(previous owner just cut the wires).
Any input on what type of fluids I should use?
The fatter of those two, on the bottom of the tank, is for fuel overflow, this also should just have a length of hose connected, and routed down, like the smaller vent line, neither of these hoses should have something connected to the other end, they should just hang free, about 1 to 1 1/2 foot or so... you'll see little channels for these hoses to sit in, on the frame, as you lower the tank in place - just make sure neither line is kinked when you have the tank in place.
All vacuum lines need to be plugged. Any open ones will cause your bike to idle poorly and run like, well, you know. Oil change will take care of the tranny, as the engine and gears use the same oil supply. 10-40 Golden Spectro is my oil of choice, but there are many good quality oils out there. Oil changes on schedule are more important than the brand of oil. Like JNS said, the tank vent lines just need to be proper length and not kinked or capped.
I am pretty fed up with this bike. I want to get it running but I am sick and tired of fixing other people's mistakes. Put a "new to me" harness on since the other one was soo cut up. Put new throttle cables and throttle tube on because the other ones were bad. Fired her up and gas is pouring out of the carbs. As soon as I turn my tank to on or reserve it starts pouring out.
