Seat release for F1?
on
1 Post
I want to make my seat easier to remove quickly. I've already changed the OE seat bolts for ones with an Allen head, I can use a long ball end key to remove without taking off side panels. But it still is a pain, especially trying to get them back in! Any ideas? Hook or pull release et cetera. Any ideas appreciated!
How about electric actuators? I'm planning to fabricate a button operated system to my Daytona from electric car door lock motors. They don't have much push though so the pins should need to go into the holes without much force. There are small electric solenoids in ebay that has more pull force but the stroke length is usually very small, like 8mm or so.
If you want I could scribble a some sort of an illustration tonight of a few ideas I got. Making them work for your bike falls to you though. Do you have a welding rig?
on
1 Post
Good thought, but the main problem is the access to the seat bolts and replacing them with the side panels on. I have perfect OEM panels so only stress them when necessary lol! I don't really know if there is enough metal to make a slot work. I will check it out tomorrow. Thanks!
