Rear Rim... Bigger!
Old 03-29-2017, 02:51 PM
courior's Avatar
Talking Rear Rim... Bigger!
Hi all.
I was after a bigger rim so i can bag 160 sized tyres for free to do some stunt practice and make some smoke! My friend happened to have a Hyosung GT250 rear rim for sale with spacers, disc and sprocket. I removed my slightly bent rim (another reason to swap) and the hyosung rim looked like it was gonna just fit out of the box so to speak... it almost did!! I just needed to file away a mm or 2 from the inside of the caliper mount to make space for a slightly larger disc, then used the original hurricane sprocket side spacer with a 2mm washer to space the caliper mount dead centre, and cut a few mm off the original hyosung sprocket side spacer to space the sprocket side perfectly in line with the gearbox sprocket. The hyosung wheel axle fits with no issue through the swingarm holes/chain adjusters but is a little too long so i will cut some more thread into it to allow the nut to tighten onto the swingarm... I will get a custom made spacer for the disc side to replace the honda+washer setup i have but for now it looks like its gonna work great!! (waiting for a new 55T sprocket before i button it all up) .. its a little heavy but fatter rubber here i come!!
Old 03-30-2017, 06:47 AM
dennisgb's Avatar
Pictures or it didn't happen.
Old 03-30-2017, 08:35 AM
courior's Avatar
Here it is mocked up
This was the only issue!
Video of rim spinning
https://goo.gl/photos/PwD4fuscCvuf8nQP9
I havent buttoned it down as its going to come off again anyway for paint and sprockets and of course the mentioned FAT RUBBER :P
Old 03-30-2017, 07:29 PM
drakito's Avatar
I run a 160 rear on my Cane. It fits with the stock rim. You just need to remove some pieces, parts, etc. I had to upsize the front slightly as well to get it to still handle normally.
Old 03-30-2017, 08:52 PM
dennisgb's Avatar
Looks good but you should get some rubber on there to make sure it all fits.
Old 03-31-2017, 01:44 AM
courior's Avatar
I read everywhere that a 160 on a stock rim will make the tyre crown and collapse a bit on corners and its not safe... But either way, wider rim is better for stunts and if the arm and chain allow, the rim can take bigger than 160 I think. I'm gonna run whatever I find for free as its a stunt/street fighter, not going for high speed cornering on it
Dennis, the tape measure says the rubber will fit.. But yeah need to wrap the rim in something to be sure will post more pics as I go.. Got at least a week before the chain and sprockets arrive, so will be on the lookout for rubber in the meantime. Summer is coming, wanna get this sorted asap now!!
Old 03-31-2017, 06:44 AM
dennisgb's Avatar
Will probably be fine with the 160 but I always want everything in place when I do mods like this to be sure, particularly when you need spacers.
Old 04-28-2017, 09:51 AM
courior's Avatar
Well its been a while waiting for parts... But finally she's on the road again!! 55t rear sprocket and new chain on the bigger rim. Got a 150 tyre on there but plenty of space for a 160 or even bigger.
image hosting free
mitchedwards81
04-18-2014 01:25 PM
tutman6
03-04-2010 12:40 PM
mitchedwards81
01-14-2007 06:23 PM
greymustang
01-06-2007 06:24 PM
InTheMaking
11-09-2005 01:45 AM
Quick Reply: Rear Rim... Bigger!
