Not starting... Pump clicking noise...
Hi guys i am new hire so if there is a thread abut this berried somewhere in there i apologies in advance.
To the point, i moved from Greece to Norway 2 years ago and sins i moved i didn't have a bike. Not long ago tho i bout a CBR 600 FH, the 87 model. It was somewhat cheep and nice looking, a rebuild to cafe fighter. I rode it 700km to the town i live now with no significant problem. Tho today after my day at university it wouldn't start. There where power in the battery and the starter was turning. I even smelt gasoline after i pumped the throttle an played with the chock, but nothing. After some time in frustration i tried to push in gear and it started. Tho the fuel pump maid a clicking noise every 2 to 3 seconds and when i felt the tubes there was pressure kick whenever there was clicks. Tho i think it stooped as i was in somewhat high rpm's as i was on the way home. After i parked the bike at my pace after 30 secs the clicking was back. Can it be that i need a new pump?
Thanks in advans
Thanks in advans
If the battery is able to turn the starter without a problem I would rule out parasitic draw, and charging system or battery problems. It's should be getting fuel as well since you mentioned a gas smell after trying to start the engine.
After riding it back home does it start up and run now on its own, or still have a problem starting and/or running? I'm thinking the engine may have become flooded due to the carburetors needing to be cleaned & adjusted. If it still will not start check for spark on all 4 plugs, and verify engine compression is good. (If it cranks over smoothly without skipping a step the compression should be good enough to start the engine). Assuming spark and compression are good I would check or replace the fuel filter and fully clean the carburetors and re-sync them if possible.
I'm with Tahoe on this one. Based on what you have told me you can likely rule out the fuel pump or starter being the problem. I think the most likely problem is spark plugs/wires/ignition system and a good healthy cleaning of your carbs and a new fuel filter. If those cheap things dont correct the problem you could go rent a compression tester and check compression.
I should mention that there is a thread running around here somewhere by CorruptFile detailing how to build a new ignition system (coil on plug) from parts off a newer bike if you find that the ignition system is the problem.
Hey Dennis, any experience with the K&L pump? I need a new one but cant find an original one anywhere. Honda dealership near me says they dont make em anymore!
