new 89 f1 owner with wierd problem
hey everyone just bought my f1 3 days ago and love it but my problem is that when i am accelerating it starts to bog until i open the throttle up alot more and also it boggs when trying to stay at one speed. any help would be great thank you[/align][/align]
RE: new 89 f1 owner with wierd problem
I have a similar problem as yours and am trying to figure it out. Mine bogs mostly when I try to really open the throttle and does it especially while on the highway at around 70mph. It seems that I'm running too rich and while I have yet to adjust the pilot screws, I believe the real issue may be with the main jets. I may need to go down a size but have yet to find the time and get into it.
Welcome to the forum and gl in finding a solution. Please let us know if you do.
I'm kinda new to motorbikes. But I was thinking it might be your Carbs are out of synchronizing? There is 2 pilot screws on them that you have to adjust for them to work proply with each other. And I've been told theres a sync tool you can buy to help you set them. Otherwise you need a tachometer
Since I last posted in this thread, I did a number of things that sorted most of my problems out:
- Took the carbs apart and re-cleaned everything carefully
- In the process, discovered I have 102 main jets (will upgrade eventually)
- Covered the brass tubes next to the intake boots as described in this thread
- Re-adjusted the pilot screws
- Put some seafoam in the tank and in the crankcase (not much)
- Covered half of each one of the two intake holes on the frame (to avoid a lean condition at highway speed - my intake holes on the front fairing are 'oversized')
I am amazed at how good she runs now. There's still a VERY slight hesitation around 6-7k rpm in high gears when at WOT but nothing to go crazy about. Otherwise, she revs right up to redline and even scares me in the process . Can't wait to see result once I put larger jets in.
