carburator floats
Old 06-08-2011, 10:11 PM
landfast's Avatar
Default carburator floats
want replace the carb floats in my 88 hurricane. do the floats need to be relaced or do they just need to be cleaned, and when takin the floats out is there a chance you could knock the carbs out of syncronization, is there anything i need to be careful of or need to look out for. ive never taken the carbs apart so any insight would be greatly appriciated
Old 06-09-2011, 11:50 PM
FR!TZ's Avatar
it really depends on the shape the floats are in. my carbs leaked and we opened up the float bowls and there was some dirt in there. but the floats were fine. just inspect them when you open it up. post a pic if you're unsure and you can get a better opinion. as far as the synchronization, i'm not sure. hopefully theres a senior member who can answer that haha
Old 06-10-2011, 09:49 PM
landfast's Avatar
cool. thanks for the advice dude. but now i have a question about the fuel pump. i just picked up this 88 hurricane that doesent run. ive been pokin around troubleshooting it and the other day i pulled the fuel line running from the pump to the carbs off the carb side, stuck it in a bottle and cranked the engine over. no fuel came out. im not really familiar with a carburator setup but shouldnt the pump be pumping fuel out out this line, even just when the key is in the on position much less when the engine is being cranked over? any help with this would be great as its hard to find a fuel pump for these bikes without breaking my bank.
Old 06-11-2011, 06:37 AM
FR!TZ's Avatar
Default yeah
yeah, it should be pumping through to carbs. i'm not sure about if it does that with just the electronics on, bet i believe not. but when you turn the engine on it should pump gas through. although, i don't know enough about the fuel pump to really give you any advice further that that, sorry. but i hope for your sake its an easier fix than replacing the pump because it would be expensive
Old 06-13-2011, 05:56 PM
landfast's Avatar
yeah dude just bypassed the fuel pump relay yesterday and she fired right up! friggen pumped!
peter jeram
03-16-2014 07:13 PM
Mbennett
03-06-2013 07:16 AM
COLT
08-10-2010 04:04 PM
chesthing
01-04-2007 11:39 PM
mxaniac
05-23-2006 06:59 PM
Quick Reply: carburator floats
