carb removal
RE: carb removal
did you loosen the black rubber bands on the bottom, that attach to the intake. If so then your next move is get over the bike like your getting on and pull with some force, they kinda weld on. But becare ful not to pull extremely hard cause your throttle and choke cables still attached.
RE: carb removal
There are no bolts, but maybe you just said "bolts."
If you see the black hard rubber manifolds between the carbs and the head, there is a collar with a phillips screw on each side of the black rubber manifold, for a total of 8. You need to unscrew those phillips screws until the collars are loose on each manifold. That's it.
If they haven't been off in a while, it's gonna suck. Heat will help, either a hair dryer or (if you're VERY careful and know what you're doing) a small torch. Work the carb forward and back in the frame and try to pull up. Don't try to pry it or wedge it or anything, bcause if you crack that aluminum piece the airbox screws onto it's not a good thing.
Be patient, and try not to mess up your hands, and good luck!
EDIT. Maybe let's not use a torch right now.
RE: carb removal
If you're absolutely positive you have everything loosened up, you could use a prybar or a broomstick, but that really increases your chances of messing something up. I don't wanna read in the paper about "Man killed in bizarre blowtorch-broomstick accident in garage."
The first time I got mine off it took an hour or so of rocking that assembly, and WD 40 and PB blaster and screwdrivers and busted knuckles.
