stupid bolts on calipers
Old 12-10-2008, 07:04 PM
thegreenbandit's Avatar
Default RE: stupid bolts on calipers
Which caliper are you talking about? Did you push the old pad in with a screw driver first to push the pistons in? Then on the outside of the caliper theres 2 plugs, that you need to pop out. Under them is the caliper pins, lossen them, then just pull them out with some needle nose pliars or something.
Old 12-10-2008, 09:59 PM
the fronts are allen heads, 5mm if I recall right on mine. I still dont understand the 12mm bolts mounting the right caliper, and a 5mm along with something of a different size screw/bolt on the left caliper holding it together. least they're easy to work on.
Old 12-11-2008, 12:37 AM
Gearloose's Avatar
I think I know the flathead screws you mean... they cover the allen headed pins. I use an impact driver. Works a treat.
Old 12-11-2008, 05:41 PM
mine has these allen head screws behind those. on mine they're 5mm size. the rear has that 10mm bolt holding a clip in that keeps two sliding pins.
Old 12-12-2008, 03:13 PM
Gearloose's Avatar
They are there to keep crud out of the sockets of the allen head sliders, so I'd tend to refit them, especially if you are in a damp environment. Must be heaps of them around on damaged calipers at wreckers.
Old 12-12-2008, 03:37 PM
screw those things, I'll find me some rubber/plastic grommets that fit the holes better and dont seize up in them. do the same job but less pain in my ****.
BakaN20
04-12-2011 12:08 PM
MartiniRossy
06-11-2009 02:42 PM
mouser
04-25-2008 10:10 AM
dwschultzy
12-03-2007 08:47 AM
Quick Reply: stupid bolts on calipers
