1989 CBR600F part out. ALL PARTS AVAILABLE
Hey guys, i recently had a pretty decent crash where i ended up flying 360 feet.
As such, im doing a part out. I have every part to the bike with the exception of the handle bars, levers, tank, and subframe for the tail.
Everything has 28,177 miles on it. i put 8,000 of those miles on and did four oil changes in the time ive had it. The frame APPEARS AND I EMPHASIZE THIS, APPEARS, to be straight, aswell as the swingarm.
i have the title in my name, and heres the only bad part, the title says 80,900 miles because the previous owner has crappy hand writing and made his 2 look like an 8. clean title currently.
tell me what you want, ill look up common resale prices and we can make a deal, if it needs to be shipped ill be using either usps or ups. I WILL NOT PAY SHIPPING.
Located in centeral NJ, 5 miles from belmar.
UPDATE!!! Ignition, gas cap, front cowl, radiator fan/temp switch, -1 front sprocket are all sold.
UPDATE 9/12: water pump and rear axle sold!!!
UPDATE 9/19: clutch cable sold
Update 2/16/13: all rotors and pads, and fuel pump sold
pictures of the parts:
chain is a 530 D.I.D X ring chain, and sprockets are sunstar, stock tooth number. i also have a -1 sunstar front sprocket.
wires and coils are available, and the fuel filter is one year old with 8000 miles of gas through it. if you buy the sprockets, chain, wires, and igniters ill give it to you lol
new xring chain ranges from 120 to 200 depending on where you look, so 80?
cleaned and lubed every 500 miles with chain wax or belray super clean chain lube, ill clean and lube before shipping if necessary.
rear sprocket may be a JT, its a 43 tooth and steel. new they are 40, how about 20?
front sprocket is a sunstar 16 tooth, looks like retail is 25 new, so 10?
wires and coils ill do for 70
and if you buy 2 or more ill give you the fuel filter
front fairing is from a 929, and is... actually in suprisingly good condition for the crash, 2 small cracks what would be easily repairable, you can have it for 30,
The headlights were 200 when i bought them, your going to need three metal wire thingys to make the one light sit in the housing "they were lost during the crash". other wise i just tested them and they work perfectly fine! the housings on the lights have some rust, nothing major, one has a 2.5 inch crease in the back, no effect to performance, and the other has a dent on the back. this is the same damage you could expect with these on a car or truck. so im thinking 130 for the set with wiring harness, ill label the wires also.
