Oil Change - Semi Sythetic or Fully Synthetic
Old 05-01-2006, 05:49 PM
corrcullen's Avatar
Default Oil Change - Semi Sythetic or Fully Synthetic
Just bought a 2005 CBR1000RR with 300 miles on the clock.
The engine isnt even fully run in.
I am going to change the oil immediately, so I was wondering should I use fully synthetic, or use semi-synthetic for a 1000 miles or so, then change to fully synthetic?
Or what would you guys recommend?
Any advice would be appreciated.
Old 05-01-2006, 06:10 PM
Default RE: Oil Change - Semi Sythetic or Fully Synthetic
You do not want to use a blended or full ysynthetic oil yet or you will not get the propper break in done. Use the same oil theat Honda does, I think it's HP4, until about 1200 and change to a blended synthetic. Blended synthetic at 2000 and then fully synthetic at 3000.
This is what I follow, give take a couple hundred.
Old 05-02-2006, 12:13 AM
jer's Avatar
jer
jer is offline
what i was told by a professional mechanic.... (over 30 yr working on bikes).......change to synthetic at 3000 miles.............slight variation to wheelieit's but basically the same.
Old 05-02-2006, 01:13 AM
i changed mine at 270- came out like water-from a friends who works for american honda- the factory oil is break-in-mine came out like water-no shavings though,i used honda gn4 petroleum and will change it again @600 and will go to full synthetic @1000- i was told this was fine and to use petroleum for proper seating of rings for the first 1000 miles-phil
Old 05-02-2006, 05:01 AM
I run mine on semi..my 05 did about 2500 miles on fully and it burnt it like mad!!!!
Old 05-02-2006, 01:01 PM
Yes, you should use the petroleum oil for your break in. Then I always go to a synthetic blend because petroleum oil and fully synthetic do not like to blend really well. I will use the synthetic blend once or twice before going to the fully synthetic. Best way to describe is trying to mix oil and water, extreme example, but affective. This way when you drain your oil you will get all the mix out of your bike.
Old 05-02-2006, 02:01 PM
AAWWWWW, crap, going to have to change my oil again. Just changed it this weekend to full synth. Seems like you guys are saying that I need to step into synth instead of jump right to it.
WHY?
Old 05-02-2006, 02:54 PM
I've got 7000 miles on the bike now and have ran nothing but Synth/Petrol blend. Bikes runs great, no worries.
Old 05-03-2006, 02:25 AM
I run full synthetic in mine. Honda oil ht-4 i think it is. Runs like a charm.
Old 05-13-2006, 10:38 AM
I just did my first oil change (595 on the clock) and I was about to cry when I saw all those metal shavings coming out of the engine. I just used HP-4 (synth/petro blend without Moley) just like the service manual calls for.
Quick Reply: Oil Change - Semi Sythetic or Fully Synthetic
