How to know if regulator or stator is bad
Old 07-04-2015, 08:22 PM
jabroni racing's Avatar
Default How to know if regulator or stator is bad
2006 CBr 1000rr, When to start the bike, gauges all lit up when key turned, hit the starter button then click, everything went dead. Checked all fuses, figured battery was shot but when i jump (cables to another batter) the bike it will start and run but as soon as i remove the cables its shuts right off and no power at all, how do i know what to replace??? Ive been told voltage regulator & possibly stator..
Old 07-04-2015, 10:09 PM
74demon's Avatar
Sounds like the battery is no good.
Try a good battery and test the voltage while its running. Hopefully you have 13.5 to 14.5.
Old 07-05-2015, 06:15 AM
if it was the battery, once its started and i un-hooked it the bike shouldnt have shut off, the alternator shouldve kept it running... that what ive always been told
Old 07-05-2015, 08:06 AM
74demon's Avatar
Check your voltages. The charging systems don't charge all that much at low rpms, if at all.
Old 07-05-2015, 08:14 AM
That works fine on a car, but not on a bike. If your battery is dead, the alternator is not enough to power everything.
Old 07-05-2015, 08:53 PM
Are you serious??? so if the battery is straight dead, and i jump the bike, the bike shouldnt stay running??? Ive never heard of that.. when i jumped it i tried it with & without the bike battery hooked to connectors, the same thing happened, as soon as i unplug the jumper batter the bike shuts off and no power at all
Old 03-30-2021, 11:56 PM
Jeff Attaway's Avatar
Try replacing the kill switch ,
Old 03-31-2021, 12:34 PM
Hi Jeff,
That post was from 2015 so he has probably sorted it one way or another.
Please introduce yourself to the forum, where are you from, new to biking, had loads of bikes hobbies etc.
We also love pictures
Ryanrad2008
08-21-2017 03:00 PM
killbee
09-02-2009 11:50 PM
95ninehundredRR
01-06-2007 09:11 AM
Quick Reply: How to know if regulator or stator is bad
