Cbr1000 won't start
Cbr1000 won't start
Hi folk i just buy a cbr1000rr 2008 and Now i have an issue i won't start
The fuel pump do not prime when i put key on
I Check
Main fuse 30a
Sub fuse 20a
Sub fuse bank angle
Engine stop switch
Ignition switch
Duel pump relay
Engine stop relay
Bank angle
I swap the ecm/ecu
I open the Half of the wiring harness
Shake and squeeze de wiring harness
My next guess is to change all the wiring harness
Somebody have similar problem or the solution or another guess to try ?? if is it cry i try too lolll
I Check
Main fuse 30a
Sub fuse 20a
Sub fuse bank angle
Engine stop switch
Ignition switch
Duel pump relay
Engine stop relay
Bank angle
I swap the ecm/ecu
Slim@SBF
12-09-2007 08:53 AM
