Spark Plug Torque
Have to agree with that, I'm pretty sure back in the old days, before we could afford torque wrenches the rule was "half a turn less than before it snaps".
To carry on from TK's method you can always keep going til you feel it thread start to go soft then back it off slightly and cross your fingers.
Personally I have never touqued spark plugs I just use a 3/8" drive mini rachet and just tighten to wrist tight but then I have been mechanicing for 40+ years so I guess I have developed a bit of a feel for how tight things should be.
Having said that a lot of things like diesel engine head bolts are now torqued to say 24ftlb and then a further 90deg followed by another 90deg. It doesnt sound much but I can assure you that it is almost to the stage of needing to use a 900mm wrench bar to achieve it.
Ditto JK, you literally can't strip the thread using that method. Though I bet some muscle man now proves me wrong.
I'll rephrase. With my candy a$$ed Entomologists wrists I can't strip the sparkplug hole thread using that method.
Cheers, SB
Cheers, SB
I'll check them OK after a few hundred miles
