wierd rattle noise from right side crank case
Old 04-03-2014, 10:36 PM
huricanetommy1.0's Avatar
New Member
Talking wierd rattle noise from right side crank case
Some one told me that the rattle noise is normal on an 88' 1000f. Sounds like a quarter in a pop can. Over 2k rpm it goes away.
i did here what sounded the same on a couple youtube vids. If you listen close its there pretty destinked noise.
Does this sound familiar to any one or should i be worried.
Guy said it was the timing chain guide or tentioner??
Old 04-04-2014, 06:44 AM
caldercay's Avatar
Is it noisiest when cold, as when you first fire it up? And does the rattling subside after the bike warms up?
In all likelihood, yes, it's probably the cam-chain tensioner. It's a well-documented issue with the Hurricane and not just with certain year models.
With that said, it *could* be something else. Carbs might need balancing. Could be the tupperware rattling, but most likely the tensioner.
Howto to fix it:
https://cbrforum.com/forum/how-tos-8...a-thai-143024/
Old 04-06-2014, 08:42 AM
New Member
Howto to fix it:
thanks for the input the noise doesnt ever go away but yes it gets quieter warmed up
Old 04-08-2014, 08:17 PM
Sprock's Avatar
Time for a new CCT and Cam Chain, right away since it's rattling all the time, imo
Old 04-09-2014, 06:48 PM
cb2cbr's Avatar
Likely the cam chain/CCT but try adjusting the balancer too. See the how-to:
https://cbrforum.com/forum/how-tos-8...stment-107818/
Old 04-10-2014, 10:46 PM
DRam's Avatar
Very Honorable Most Senior Member :)
#1. It's also amazing how many weird noises a good tune up including carb balancing will get rid of. Quite possibly the CCT and/or cam chain though.
Old 04-11-2014, 07:46 AM
Sprock's Avatar
Hear ya there DRam, CB2CBR , how's your CCT prototype coming along ? since we are
on the topic again . If there's any developments fire up that thread you had going.
Old 08-30-2015, 01:59 PM
bc30se's Avatar
have the same noise, manual cam tensioner, new camchain, new alternator chain, new oil pump chain, balanser adjusted.. what else?
There is nothing under this little cover but I hera the noise is from there...
Old 08-30-2015, 10:53 PM
DRam's Avatar
Where is the little cover located? How big is it? Do you have to remove the fairing to see it?
Old 08-31-2015, 05:19 AM
bc30se's Avatar
the one next to the clutch cover....
Kolincj
11-27-2019 10:30 AM
dan02
03-24-2009 08:08 AM
RYDRED929
02-28-2006 09:24 PM
Quick Reply: wierd rattle noise from right side crank case
