When it rains... it pours...
So, the wife & I were visiting my mom. It was raining out and after about 4 hours or so it turned out the solid surface I thought I had parked on.. wasn't so solid. The CBRs kickstand sunk and the bike fell over onto my wifes SV650. It snapped off the plastic above the headlight aswell as broke my beloved windscreen in half.
Fast forward a week. I have repaired the damage and went ahead with a plan I've had for about 2 years and coated the plastics with truck bed liner. Also got stranded one day because the bike wouldn't restart after a refuel stop. Turned out all of the fluid from the battery had leaked out.
Fast forward a day and a half, its Thanksgiving (Happy Belated Thanksgiving to you all and an early Merry Christmas aswell) and my sister-in-laws boyfriend wants to go out early black Friday shopping. Told him it'd be impossible in this town, and I was correct. I was low speed riding through a Walmart parking lot search for a space when out of nowhere the bike hickups (backfires?) and immediately after starts running horribly. Can't keep it idling for anything.
Fast forward to today, after dealing with hard starts, poor idling and rpm hangs I've decided that somethings up with the carbs causing them to be lean. Pull them off and play with the slides/pistons. #2 drops instaintly, rest slowly drop. Pull the cap and the diaphram is cracked in a ton of places.
So now my question, I've pulled the other diaphrams 3 out of the 4 need repairs/replacement. #2 id like to replace but parts stores are showing $138 for the whole slide. I found a vendor on ebay that is selling just the diaphram for $20. (Part #s match) Is it possible to replace just the diaphram? If so how do I get it off.... I'm afraid ill break the "cap" if I pry. I'm going to attempt to coat the other diaphrams in plasti-dip since they're not as bad.
Thanks for the help in advance.
on
Don't use plastic dip they'll stiffen up and won't work right - why not find a second
set of carbs cheap on Ebay ?
There's a pretty healthy selection to chose from right now
sort high to low
Also what year is your bike again ? I have an ever growing collection of carbs
out in the garage - chances are - lol - I can find you some complete slide assemblies
if you are interested PM me
sort high to low
Couple of questions if someone doesn't mind answering. What's the easiest way to get the intake manifold/boots off, that's 1 source of my leaks. Would the air cleaner lacking a filter cause any problems? I'm not refering to the air filter but the air cleaner that sits above the valve cover and ties into the vacuum chambers.
Honda put those clamps in an impossible spot, didn't they. Seem to have cured the leaks. Jets, bowls & passages are cleared. She's idling again but still having an issue with ramping up in RPM very quickly with choke on full while cold. 3 of the diaphrams seem to be good to go. That 1 I've been worried about is probably the reason. When the choke is applied it opens up a passage that leads behind the butterflies right to apply a vacuum to the chamber enrichening the mixture. If one wasn't opening it'd still draw fuel from the pilot making it run lean, would that make the rpms ramp so fast, 1 cylinder being lean?
on
Mine does that - ramp up quick when left with the choke on - you can cut that a bit
by turning in the pilots a quarter - but it'll still do it somewhat
How doe it idle with choke off and fully warmed up ? is it consistent and smooth ?
Your main needles and jets have no real bearing on things at idle - it's all pilots !
I finagle the choke a bit so that it doesn't stumble and cause me to dump the bike at low speed.
