What's the best way
Old 10-28-2012, 08:09 AM
jacknife's Avatar
Default What's the best way
Hi, what's the best way to remove hydraulic fluids from the breaks and cluch? Also the water from the coolant system? This is the part of the strip down I've not done before. Thanks.
Old 10-29-2012, 05:57 PM
Bordo's Avatar
Jack,
I use a Mighty Vac to drain fluids from clutch and brakes. I just did a clutch slave/master cylinder rebuild and the Mighty Vac was awesome. No mess at all. As for the coolant just sit a bucket around 18 inches from the water pump and let her go !!!!! Flush it with the drain screw still out and re fill. They are pretty easy jobs compared to some. Good luck.
Old 10-30-2012, 05:35 PM
jacknife's Avatar
Thanks. The water won't be going back in but I will flush it all out with a good amount of water, it's the bike break down.
Old 10-30-2012, 06:10 PM
hawkwind's Avatar
If you're stripping the bike, it's a good idea to reverse flush the radiator, will help to get rid of any crud and maximise the efficiency of the cooling system
Old 10-31-2012, 06:44 PM
jacknife's Avatar
Thanks Hawkwind, will be doing that too
