What will I see after removing the oil pan?
Old 05-10-2015, 12:19 PM
bc30se's Avatar
Default What will I see after removing the oil pan?
Hello
Is there any photo I could ask for which will show me what I am going to see when I drop the oil pan?
I will be very helpful for me... very appreciated!
Old 05-10-2015, 05:13 PM
Sebastionbear1's Avatar
You will see, the inside of the oil pan, and from the engine, an oil pick up and shiny spinny bits - bottom of conrods and crankshaft.
What are you looking for? What do you expect?
Honda Cbr1000f 1000 Hurricane 1987 Usa Oil Pump - schematic partsfiche
Cheers, SB
Old 05-11-2015, 01:15 AM
bc30se's Avatar
Guys, I just need a photo, if you have it, of the engine without the oil pan because I want to see service opportunities if I were to work on the bike from the inspection pit...
Old 05-11-2015, 07:48 AM
TimBucTwo's Avatar
There is not a lot to see with the sump cover removed. What you will see is the crank shaft minus the ends, the connecting rod caps and the bottom of the cam chain tensioner sprocket. As SB mentioned, you'll also see the oil pick-up. There are not a lot of service opportunities down there, if any. To service the lower end would require the cases to be split.
Old 05-11-2015, 08:09 AM
bc30se's Avatar
looks I have to see it by myself, I must get down to the oil pump chain..
Old 05-11-2015, 08:31 AM
Shadow's Avatar
Unfortunately you can't replace the oil chain without a complete stripdown of the engine.
Sad but true.
Old 05-22-2015, 04:11 PM
Sprock's Avatar
You could undo the oil pump sprocket cut the chain and link a new masterlink chain
to the old and manually crank the motor until the new chain comes back around the crank.
I remember seeing a chain replacement part number once about five years ago somewhere
............ if I find it - that was a half dozen laptops or so ago, I'll post it up
It's a 62 Link chain just got to find the size and pitch , one on the left of this pic from Henry's tear down
Old 05-23-2015, 06:27 AM
bc30se's Avatar
There must be a symbol stamped on the side of the link, I suppose it is a regular timing chain that can be easily relinked.
FireStourm
02-29-2008 10:30 AM
Dj_Squatch
02-28-2008 04:44 PM
n0s_speed
08-02-2007 12:00 PM
teamneon
07-27-2007 07:55 AM
discipleofgonzo
01-25-2007 12:58 PM
Quick Reply: What will I see after removing the oil pan?
