Wanting to find the alternator wattage output
Your alternator output, is 55 to 60 volts, ac. Then converted with your rr. 14.5 to 16v.dc, To charge your battery and some to the lights, ect.
These alternator are getting so hard to find. FYI
A good battery that has lots of amps. Is key here.
You would have to hook up the items you want to use, and measure the reduced load, draw at the battery.
To find our how much you are going to draw from the battery, and how much if any remaining from the stator, rr.
