Very hard to start.
Very hard to start.
Hi all
When I picked up my cbr about 3 weeks ago, it was very hard to start. In fact, i could only get it going by bumpstarting it down hill.
When returning home, it started no problem. I started it every 2-3 days and it started after 5-6 seconds of cranking. Not great but ok.
It was sitting whilst I was moving for about 2 weeks and now it wont start again.
I have a spark (and did the first time it wouldnt start either)
It backfired a couple of times, coughed but thats it. I can see visible black smoke from the exhaust so im thinking its too rich to start and fouling the plugs. It does this with both the choke and without the choke.
Any ideas where to start?
I would start and investigate the fuel delivery system, since this tends to be where rich/lean symtpons stems.
Are you aware of the service history? Have you done any service since you got it? Start with the basics. Fuel filter, then I would investigate the carbs and make sure the fuel is being deliveried properly to the motor. Did it have bad gas in it? Did it sit for a long time with bad gas in it? You could have all sorts of issues with gas getting everywhere and anywhere it can.
You should always start the CBR1000F on the 'choke' in the mornings (first start). It is actually an enricher.
Check the battery is fully charged as that is another thing they like.
Also perhaps consider the alternator damper. This exhibits slow starting (although the starter spins over as normal) as a symptom.
Cheers, SB
Cheers, SB
Hi Alexander,
I'm going to join this thread as my baby has started to exhibit poor starting symptoms recently since the weather has got cold. I had the carbs off a few weeks ago and cleaned everything out. The problem went away for a while and she'd fire straight up on the button as expected but the slow start has come back again. The engine sometimes fires first time and then dies but after another one or two spins on the starter she fires up slowly and sounds like there's only two cylinders firing for a few seconds.
I'm convinced this is a fuel delivery problem but having cleaned from tank to carbs recently I'm a bit puzzled why the symptom has returned so quickly. Once it's warmed up it will tick over evenly and run fine at any speed.
If you find anything obvious while you're trying to figure out your problem please let me know. If I find anything I will post here.
Cheers
H
Cheers
H
Good point Hawk but I have an in line filter and also cleaned the carb filters too.
The petcock filter has been cleaned out so many times I've lost count due to the fact I bought a 23 Y/O bike with sod all mileage on it. Rust remnants just keep on coming. The trouble is, you can never be completely sure that tiny particles haven't made their way into your jets.
Cheers, SB
Cheers, SB
I will keep in mind, but the starter spins over nice and fast.
Hi Alexander,
Cheers
H
Cheers
H
Mine does exactly the same. Initially it will cough, then cough a bit more, then start running on 2 then 3 then 4 cylinders.
Once it's HOT it restarts ok. If I leave it for more than 30 minutes or so it gets harder to start again, but doesn't exhibit the same scenario, when it eventually starts it starts on all 4
It say for about 3 months, but it currently has a fresh tank in it.
No servicing at all, it's all going to get done next week.
My bike has 88 thousand miles though.
When the weather is very cold, this is how I have to start her up (1990 FL, 56,000 miles):
Ignition on
Open choke fully
Press starter
Keep starter pressed while doing the following:
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Eventually there will be a hint of starting with one brief splutter
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Eventually there will be another longer splutter
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Eventually there will be another even longer splutter
May have to repeat the above once or twice more!
At the long splutter, open choke fully and she will start
It's a matter of feel and awareness of your own bike. Wish it wasn't...
However, when the weather is not so cold she'll start on choke after about a second.
Ignition on
Open choke fully
Press starter
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Ignition on
Open choke fully
Press starter
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Ignition on
Open choke fully
Press starter
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
Close the choke
Open the choke
Close the choke
Open the choke
Close the choke
