Un....believable
Un....believable
I put on a set of Michelin Pilot Road 4 GT's during the week. I used the zip tie method, and have to say it worked out pretty well. While things were apart, I cleaned and lubed up the guide pins on the front calipers, so more sticking caliper. Also pulled the plugs, cleaned and gapped them. I use Ride On Tire Sealant in my rides, because I commute quite often and don't want to get stranded miles from home. It also balances the wheels nicely without weights. So I get it all together this morning, and take it for a short ride down the alley. I get maybe 150 feet down the alley, and hear that unmistakable "pop" of something hard and nasty between the tire and the road. I stop immediately, and see a screw sticking out of my brand new rear tire!! @#$%^&*!! I could not believe it! The Ride On did seal the tire, but not completely because you're supposed to ride about 5 miles to warm up the tires and spread the sealant out. I hear air leaking out slowly, so I get it home and look at it closer. Yes, it definitely punctured the tire all the way through, about 1.5 off the centerline. I am so pissed off. A brand new tire. Unbelievable. I decided to try a plug. I know, I know...many of you will say a plug is too dangerous. Especially if riding fast (I don't). Others will say it's fine. I'm going to watch it closely and monitor tire pressure carefully. If I see any signs of leak, I will replace it.
Ouch! My condolences.
I have used plugs on four-wheeled vehicles in the past with no trouble, but would be somewhat reluctant to do so on a bike except as an emergency repair in the middle of nowhere. Losing 25% of your wheels at speed isn't too bad, but 50%? That's happened and it's a little spooky, even if it's a fairly slow leak. A friend spent quite a bit of time recuperating after a front went flat quickly at 70 mph.
Your plan to keep a real close watch on tire pressure is a good one. Biting the bullet and buying a new tire is an even better plan.
Just my opinion, others may disagree.
I have used plugs many times. I don't take the tire all the way down with a plug in it.
Option 2: Put a tube it it for the life of the tire.
I like option 1 because I'd rather have a slow leek from a plug rather than a fast leak from a tube.
I have had a tube go on a bike that I had lied all the way down just before hitting a steel decked bridge. All hell broke loose when I up righted and hit the bridge during strong winds. SCARY! I would have had a warning with a plug or crossed the bridge and started to feel the tire starting to go. Still, it takes a day or so for a leaking plug to drain down.
I would not plug a front tire however.
So far so good. The tire is holding pressure. I check it before heading out in the morning, and again before heading home. It's holding well. But, I will always keep an eye on it. I have to say the heavy beast handles SOOO much better with these new tires...it's night and day compared to before.
