turns over slow and wont start when warm
RE: turns over slow and wont start when warm
When you have been for a ride, take the plugs out (whilst hot) and check the gap as sometimes they can expand and when you tryto restart, it the spark is not as intensive as it should be. As for the slow starting, could be battery, or bad earth or down to the starting problem your having. Try the plugs first and then see what happens. Good luck
[IMG]local://upfiles/10939/2CFFBDF245EC4D37BE5BE37A30CDF38B.jpg[/IMG]
It could be a short or open overamping the wiring while the key is on. This will cause the cables to heat up and conduct less electricity. I've had this happen on my old Interceptor (electric cooling fan was drawing to high amperage)and a pickup I owned (starter cables to close to exhaust). A real pain to trace. You have to disconnect all normal power draws like the headlights and then check for current draw. Good news is you can check while the bike is cold.
Sometimes when the valves are to tight in an engine it will start when cold. When the engine warms up it will run great as the momentum of the valve will seat it. When it is warm the clearance may be to tight to get a good seal for starting. As the engine cools off the valve contracts and closes for starting. I incountered this with a few older cars with manual adjustment valve clearance. If it were me the first thing I would check is the valve clearance.
