Temperature gauge?
Warner
I recently flushed mine, new radiator fluid, pressure washed carefully the radiator grill.
I have ordered a new radiator cap and thermostat.
While I wait for my used stator to come. About all I do till then is charge battery and ride for about 30 minutes.
A few more days.
I'm actually suspecting the heat ruined the stator in the first place. Because before the stator failed, the bike would get close to the red at stop signs in town.
After reading a few posts, I did the flush and new fluid.
Which only helped a little. I was still 3/4 over on the gauge. And normal was in the middle of the gauge after 1 hour of riding.
But now that I'm in limp mode until the stator comes. I hope to ensure the bike is running cooler.
Ryan
A few more days.
Ryan
Warner
Good day all,
Normal behavior for a 1000f... What did on mine was to install a manual override swicth for when stuck in traffic too long, dies the trick. One problem i had is when it was hot it woould spew coolant trough the overfill tube of the reserve. For this not happen make sure the tube goes only halfway of the reserve, if it goes to the bottom it will behave as if the reserve tank is full.
Another problem you might encounter while stuck in traffic is that carbs will get hot and the bike want to bog down. This cauused by the fact that it is fully enclosed. Engine heat does not disperse correctly. The carbs are not mixing the mixture correctly because of heat. It is ok after you get on the open road.
Working on something for this, i was thinking of hooking computer fans to pull out the heat from the engine bay.
Will keep you posted
Just reviving an old thread instead of starting a new one.
My motorcycle get's rather hot as well but it's very variable in how it handles traffic. Sometimes it'll cool itself down well and indeed go up to around 4/5 on the gauge and stay there.
The fan comes on, everything seems in order.
However, the other day I was driving around town on a hot day and sat in traffic for probably 30min give or take.
Then this happened. Fan was running and it never get's blistering hot here (probably 18celcius). I should check my cooling system, shouldn't i?
Other times, rarely but especially if I get off the highway and hit a congestion it'll shoot up and almost touch the red field.
These bikes really goes hot quick but I'm not too worried. Especially because the temp rarely exceeds 24 celcius here
