Stood only 3weeks now fires on 3
Old 10-22-2014, 07:02 PM
Sprock's Avatar
Originally Posted by seandcontracting
Mine did 20 years on gravity feed, never used the vacuum tap setup, but I always shut off the fuel at the main pet ****. Went through three in twenty years from leakage lol. Sprock, is the vac tap more reliable? You still using stock petcock shutoff?
Point being having two bikes (90 & 93 ) with vacuum petcocks - you could
say I was inclined to forget to turn the petcock off on the gravity fed 87
So the pingel was installed inline on the fuel line to the carbs.
works same way as a mark 2 or 3 oem vacuum petcock only inline on the fuel
line.
I'd recommend if gravity feeding an 87 88
(Must mention though I have 90 carbs on my 87 so a vac port was avail)
You'd have to run vac line off carb one sync port if using an oem 87 or 88 carb set.
Hope it is as simple as a bad wire or plug though
Old 11-10-2014, 08:14 PM
mrchips's Avatar
toecutter2503
Did you get it sorted ?
Old 11-11-2014, 02:54 PM
toecutter2503's Avatar
Hi All. Yes I think I've found the problem . I rechecked the pilot jets and found n0. 1 and 4 blocked. The reason I think is due to me. The previous time I checked them, I put a smear of silicon gasket material over the original rubber gasket on the float bowl to help seal the chamber. So some squished out inside, along the edges when the bowl was clamped down. Over the weeks , I think this reacted with the fuel in the bowl , creating particles that blocked up the pilot jets. On removing the silicon , it didn't feel set , just gungey .
So , yet to test theory as I've now stripped a thread so need to fix with a thread insert. and also track down some float bowl gaskets. Any body know of a good source in the UK ?
Pretty sure thats the problem.
Old 11-11-2014, 04:52 PM
hawkwind's Avatar
Old 11-13-2014, 10:37 AM
mrchips's Avatar
That's great news that you found the problem.
cbrprospect
10-22-2010 01:22 PM
njdjh2o
03-20-2009 09:22 PM
partytime
02-12-2009 08:59 AM
Hoshino
12-14-2008 04:12 PM
compulady5
04-10-2007 12:03 AM
Quick Reply: Stood only 3weeks now fires on 3
