Starting/Battery issue
Old 10-24-2013, 12:36 PM
mrniceguy's Avatar
Default Starting/Battery issue
So the other day the bike stalled out on me. When I pulled over to a safe spot it would not turn over. After 2 tries I could tell the batt was low. My wife came, gave it a jump rode it home. Later that night it started and rode just fine. Put battery tender on it anyway. A few days later I go to start it up and its dead again. Swapped batteries from the other CBR and same thing. Both batteries read fully charged on a tester, but I cant start without a jump. Its like they are not making enough power. The batteries are less than 2 months old and the temp is around 50-70 f.
Old 10-24-2013, 03:43 PM
chimp1's Avatar
Old 10-24-2013, 06:56 PM
Sprock's Avatar
Clean ground to frame and pos terminal points
thedrewski86's Avatar
Welcome Crew
Could be the relay, test and see first though. You should also give the regulator and stator a check per the fsm. Honda was notorious for bad charging systems. I recently replaced mine and have had to do so on past Hondas.
Old 10-26-2013, 07:43 PM
mrniceguy's Avatar
well my meter is crap... so I just swapped out the switch and regulator from the bike thats waiting for the motor swap. When I went to check the regulator, I noticed that the owner before me had fitted a fan over it to draw the warm air away. Any thing you guys can think off that would cause enough heat for them to go through the trouble?
Old 10-29-2013, 11:59 PM
mrniceguy's Avatar
Cleaned all ground connections knew of and swapped starter relay, rectifier, and alternator cover/stator coil. Still having issue. I plan to get a new meter when I get paid. Will start and run lights a seems to charge the battery. I only have an issue after longer ride.
Old 10-30-2013, 01:39 PM
hawkwind's Avatar
The Honda OEM rectifier will get very hot, most after market rectifiers will have some type of heat sink to get around this. Bit of a design flaw on Mr Hondas part. The fan will just be the previous owner making doubly sure it wont overheat.
Old 11-09-2013, 06:05 PM
hedgemonkey's Avatar
i had exactly the same thing on mine. even put a new battery on. i ran an earth lead from one of the starter motor mounting bolts direct to the negative terminal on the battery. instant cure. talking to a mate, and apparently this is standard wiring set-up on honda shadows, goldwings and F6C's?
Old 11-09-2013, 10:04 PM
mrniceguy's Avatar
I will try that tomorrow. Thanks!
Old 11-10-2013, 07:12 PM
mrniceguy's Avatar
well I'll be.... That fixed it. Well it did for a bit, till the fan came on. After that same condition. Going to shell out for a better meter recheck the stator and the wiring to the fan. Its after market.
Quick Reply: Starting/Battery issue
