Some performance issues
I've had my lady for a few weeks she's been giving me some trouble. When I get on the throttle she bogs out around 7500rpm for a second and then usually snaps out of it and rips to redline, it's sounds like I'm hitting a Rev limiter, even my friend riding next to me hears it. Also seems a bit sluggish off the line.
All stock except Vance and Hines 2 into 1. New plugs new air filter. I haven't taken the carbs apart yet but I have given her the seafoam treatment a few times 1990
Any advice from seasoned hurricane rider?
I think this may be your problem. Seafoam can only do so much and will only delay the need to clean them in the good old fashioned way.
Not hard to do and sounds like you know what you're doing.
There is a small screen in each carb that may have some crap in there and it's well worth fitting an in-line filter to the fuel line. The in tank filter may be damaged and the tanks on these old girls are pretty old now, there may be some rust getting through.
Other things you could look at would be a partially blocked tank breather or possibly a vacuum leak somewhere.
I had the same issues with my 88 cane. Ended up taking the carbs off after praying the seafoam would work and it didnt. LOL My motor would stumble right at 7K then inhale pavement. I lived with it for awhile. Then could not take it anymore. Pulled the carbs off and cleaned them. One of the carbs was quite dirty. in fact one of the 4 sliders was hanging up, ended up replacing the weak spring from another set of carbs that I bought off ebay. Check you sliders and make sure they move freely. Also replaced all 4 carb holders some were deteriorated and leaking fuel and pulling air in after the carbs.
It was a pain in the *** to do. But after assembly and install it was well worth it. When i hit 7000k it ripped. It was like a new bike. I mean it pulled hard!! Idles super smooth, something it did not do before.
