Shad..
Old 05-02-2013, 11:03 AM
Raginmund's Avatar
Default Shad..
My '93 has a Shad wing-rack and top box.
Will Givi/Kappa boxes fit? Or do I need I need Shad branded panniers?
I asked at my local shop and they didn't know.
cheers.
Old 05-04-2013, 12:42 AM
Shadow's Avatar
Maletas y Accesorios para tu moto - Shad - Freedom to move
Maybe ask them.
Looking at the rack it should be a simple matter to mount Nonfango panniers (which is what I have) to the Shad rack, if you have the U shaped brackets.
As for Kappa/Givi - not sure.
If the pic is accurate
http://www.shad.es/descargas/shad106.pdf
The Nonfango boxes will fit.
Looks like these come with mounting plates
Kappa
http://www.gumtree.com/p/cars-vans-m...air/1016019606
35 quid ? Gift !
Best advice would be to find someone with the luggage you like and see if they will fit on your back box mounting plate - if so the chances are the panniers will fit on your bike with the correct brackets.
Old 05-04-2013, 08:20 PM
Sprock's Avatar
Not without adapters - cheapest way to go is to slap a universal Givi Monokey Mount
plate on it - using a good drill and a make it fit/mount attitude
Old 05-07-2013, 12:00 PM
Raginmund's Avatar
Thanks folks; looks like I'll keep an eye on ebay for shad or nonfango.
You can new shad panniers but £330 is way out of budget.
Old 05-14-2013, 02:18 PM
Raginmund's Avatar
Just to be clear; nonfango will fit the Shad rack? Or certain pannier models?
I ask because there is some well priced 30L nonfango panniers on ebay and I don't want to buy them and have to re-list!!
Old 05-15-2013, 12:06 AM
Shadow's Avatar
Yes I'd say so BUT YOU MUST BUY THE MOUNTING PLATES that the boxes attach to - U shaped things. If you need pics let me know.
The U shaped brackets should mount to the Shad "frame" - you may have to drill a couple of holes but I had to do that anyway on my set which is designed for the 1000F.
Old 05-15-2013, 03:13 AM
Raginmund's Avatar
Thanks Shadow; are the brackets still available, or is it another lurk on ebay job?
Old 05-15-2013, 09:02 AM
Shadow's Avatar
NONFANGO PANNIER RAILS EARLY TYPE SOO1 U BRACKETS SIDE KIT | eBay
14 quid on e-Bay !
All earlier nonfango boxes fit these as far as I know.
here's a whole page of Nonfango stuff - every bit as good as Givi and a much neater fitting arrangement.
http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
There's a whole set for 120 quid with frames the lot - same page
http://www.ebay.co.uk/itm/Nonfango-X...item2c6ecb7d0f
- almost identical to mine. I've had mine for 8 years now and they can carry a LOAD of stuff and don't affect the stability too much. I've had mine loaded at 100MPH with pillion on the motorway and didn't even know they were there.
Old 05-15-2013, 01:15 PM
Raginmund's Avatar
14 quid on e-Bay !
Nonfango luggage | eBay
Nonfango X3 45 litre boxes and racks motorcycle luggage like Givi | eBay
Shadow, that's great, many thanks
I just need the panniers and rails as I have the wing-rack and a shad topbox; I'll certainly buy the side rails if I win the pannier auction (or maybe even if I don't).
Here's hoping I can get a full set-up so I can take my son camping in July (he's been pillion on the 1000F twice and loved it).
Old 05-16-2013, 09:10 AM
Shadow's Avatar
Here's a couple of pics of my bike with boxes mounted and without - note the rail to mount the U brackets is very inconspicuous, unlike the Givi system.
If you mount the U brackets to your side frame of the back box of your Shad system you should end up with a similar system. These are 3x48Litres - hold a ton of stuff !
